typhoon boom fitting
JBA
Post by JBA »
Good evening allo
There is a short (4"? long)) 1" wide track on the underside of my boom about 12" from the aft end of the boom. Does anyone else have one? Does anyone know its purpose?
JBA
Nick Price
Boom track
Post by Nick Price »
Don't have such an animal on my Typhoon but I suspect it will may have been used for the clew outhaul in some fashion or maybe used to attach a pulley for the mainsheet. Do you have the usual stainless double ended strap in the end of the boom. One end for the mainsheet pulley and one to hook it to the back stay strop when at a mooring?
Nick
JWEells
Location: The Typhoon "Valaskjalf" (#1842), in Lake Arrowhead, California.
Boom bail...
Post by JWEells »
... for preventers?
Cuique Sententia Mea
Gary M
1982 CD22
Marina del Rey, CA
On the underside of the boom?!
Post by Gary M »
JBA
I don't remember ever seeing a track along the underside of the boom.
A reef line would use the side of the boom.
I could be an experiment by the PO.
JWEells
Zspar boom from Rigrite
Post by JWEells »
Check the Rigrite site, as it seems you have a Zspar boom. I clipped this:
<i>Boom Bail Assembly - 20mm Heavy-duty: Z-3044AW:
Welded SS Boom Bail fits in integral track in underside of Z160, Z204, and other boom sections with a 20mm wide track. As Z-3044A (above), but bail is welded in position and does not articulate. Formed plate is 2mm thick and measures 3 1/8" (80mm) long x 13/16" (20mm) wide. Fastens with (2) 3/16" (5mm) rivets.</i>
