Nonskid gelcoat repair
I'm planning to repair a cracked area of the nonskid deck of our '82 CD25. Any suggestions as to materials, color matching, and technique would be greatly appreciated. I seem to recall reading an article which mentioned a method of duplicating the nonskid texture by using an imprint made from an undamaged area. Does anyone else have any information on this?
Re: Nonskid gelcoat repair
If i remember correctly, you wax an undamaged area of the deck, build a small dam around the waxed area with modeling clay and fill with silicone.After the silicone cures, remove the clay and peel off the silicone imprint.I'm sure the wax acts as a release agent for the silicone.Brian A. wrote: I'm planning to repair a cracked area of the nonskid deck of our '82 CD25. Any suggestions as to materials, color matching, and technique would be greatly appreciated. I seem to recall reading an article which mentioned a method of duplicating the nonskid texture by using an imprint made from an undamaged area. Does anyone else have any information on this?
nauticalw@aol.com
