does anyone recognize this port on by CD25?
[img][img]http://img70.imageshack.us/img70/9273/img1642rt9.th.jpg[/img][/img]
[img][img]http://img69.imageshack.us/img69/8282/img1643bb9.th.jpg[/img]
[/img]
CD 25 Port
Moderator: bobdugan
Holding Tank?
The holding tank on my CD27 is vented in a similar location on the port side; I have since added a second vent near the toerail at the head (very close to the tank) which significantly improved ventilation (and odor).
BTW, when I added the second vent, I installed a T fitting and connected the top of the vented loop to this line as well - and then Rhode Island became a "no discharge" zone and the vented loop has been dry ever since!
Duncan Maio
s/v Remedy
CD27 #37
Bristol, RI
s/v Remedy
CD27 #37
Bristol, RI
Not factory installed
Hi Scott,
FYI - This vent must have been installed by a previous owner because it is not original to the boat. I'm curious if you've ever experienced seawater intrusion into the vent. It's in a location that can get a lot of spray and, under the right (or wrong) conditions, could actually be submerged for very brief periods of time.
If you do get seawater intrustion, you may want to consider investing in a shield to go over this vent. I tried unsuccessfully to get a part no. off West Marine's web-site. Basically, it's a shield that deflects water away from a hull penetration. You see them a lot on marine electronics to keep rainwater away from where a wire comes through a hole in the fiberglass. In this case you'd mount it sideways. Just a thought.
Carl
Carl
Sir Isaac Newton
Sir Isaac Newton
CD25 Port
Scott:
My CD27 is a 1977 model, hull #37. I think the holding tank setup was original to the boat - there is a deck pumpout, a tiny (six gallon) holding tank and an overboard pumpout, so you can either pump directly overboard from the head, pump the holding tank overboard, or use a pumping station or "honey wagon."
The original vent had a long horizontal run forward, which could collect liquid if the tank overfilled or from condensation - that's one reason the experts recommend short vertical runs for vent lines.
The Big Plan for the boat involves a new, larger holding tank, either under the port settee berth or under the vee berth (where the water tank is, and add a water tank under the settee); either one will get the tank closer to a vertical run to a vent.
Duncan Maio
s/v Remedy
CD27 #37
Bristol, RI
s/v Remedy
CD27 #37
Bristol, RI
