How do you remove POLY GLOW
- Les Bloom
Portsmouth, RI
Put POLY GLOW on Spring of 2005. The stuff has been crazing and peeling off. I hate it and I want to remove it completely the fall afteri pull her out. Anyone else had the same problem with this in the northeast . How do you get the junk off ??
Les Bloom
- Cathy Monaghan
Poli Prep
The company that makes Poli Glow also makes the remover. It's call Poli Prep.
CLICK HERE for Poli Glow Products:
CLICK HERE for the Practical Sailor article regarding fiberglass hull restorers. It's reproduced here by MyBoatStore.com but it is the same as what appeared in the April 1999 issue.
Les:
I like the stuff, and have used it every other season or so for the past several years. ZEP Purple Cleaner (Home Depot) or any acidic cleaner will take it off, as well as the stuff that the Poli Glow folks sell.
Was it hot and sunny the day you put it on? I usually do it on a warm, but not too hot day, and early or late in the day to avoid bright direct sun. On my CD27, I usually get two full applications of 3-4 coats from a bottle, and two to three seasons from an application. I prep with Purple cleaner and Soft Scrub, not Poli Prep.
Duncan Maio
s/v Remedy
CD27 #37
Bristol, RI
s/v Remedy
CD27 #37
Bristol, RI
windex?
You might give Windex or similar ammonia-based cleaner a try if there is nothing about your hull that would be affected by it.
It sounds like the hull wasn't thoroughly prepped; either chalky or waxy. I've use the stuff for a few years now and have never had a problem such as you describe. I'm very happy with the product.
Tod Mills
Tartan 26 project boat
Cape Dory admirer
Cape Dory admirer
- Michael Ellis
I used Poli Glow once and tried various methods of trying to remove it. The irony is it seemed to come off where the fenders rubbed, but I couldn't get it off with the Poly Glow stripper, or by using a buffing compound. I was told the only good way to remove it was using an industrial floor wax remover. I sold the boat before trying that.
Mike Ellis
Mike Ellis
Flush with copious amounts of water
In using the Poli-Prep or other ammonia-based cleanser, the instructions are very clear that you should scrub a manageable area with the cleanser and *immediately* flush with a lot of water from a hose. Probably have to repeat to get it all. Otherwise the cleanser dries up and leaves the Poli-glow on the surface.
application method
I've bought BUT have not used the stuff, PLOY GLOW myself. I have read the instructions and it states very clearly to use the prep PRIOR to and in order to remove POLY GLOW. Since you seem to have missed that tid bit I'm wondering if your problems might be the result of NOT using the prep prior to application of POLY GLOW.
I sure don't want the problems you're having so I'd appreciate knowing how you applied it.
Randy 25D Seraph #161
