I've never dealt with shrink wrap and would like to know if I can
put in a zipper door in existing wrap...what materials I should get
from a boating store, do's and don'ts. I am very handy, but this is
new territory. Thanks for your input(s). Bill
Shrink-wrap question
Re: Shrink-wrap question
This late in the (Winter) season, I'd take the cheap way out. Heavy plastic sheet and duct tape. Slit the shrink wrap so you can get in/out. Cover the slit with an oversized square of plastic and seal the sides. You should only have to partly unseal to fold back the "door."
- John Danicic
Dr. Shrink
Bill:
If you really need a door, you can purchase one from Dr. Shrink.
http://www.dr-shrink.com/retail_access_doors.html
These doors are zipper openings with a mounting "frame". Simply tape (use shrink wrap tape) the frame over the area you want to get in, un zip the door and cut out the plastic inside. Save the door in the Spring. They are good for three or four seasons.
Speaking of Spring. Time to start waking up these two babies under shrink wrap in Northern Wisconsin. Left CD 36 right CD33.
Sail on.
John Danicic
CD 36 - Mariah - #124
Lake Superior
Sail on.
John Danicic
Lake Superior
- Joe Myerson
Plastic mailing tape
I've always used an approach similar to Neil's.
Taking a utility knife, I cut a door-shaped opening in the shrinkwrap (in the shape of an inverted "U" actually). Then I use plastic mailing tape to seal it up.
I find that the lightweight tape holds well. Sometimes, if it's been a long time between uses, I have to cut the tape, but all that does is build up extra plastic around the door opening.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
