Cape Dory 25 Wisker Pole Attachment
- Location: Cape Dory 25 Sailboat, SeaQuill, Rochester NY
I bought a 1978 Cape Dory 25 last year. Part of the gear included a wisker pole, but I don't see where to attach it on the mast. There is no hardware that I can see for this purpose. Can anyone tell me what to look for and or what hardware I need to install for this purpose? Thanks.
CD27 #105
Annapolis, Maryland - Contact:
There should be a fairly heavy padeye on the front of the mast, about 3' to 4' above the cabin top. Here is the page in the forespar catalog (no picture):
http://www.forespar.com/onlineCatalog/0 ... 2006.shtml
Seasprite 34 "Sarah".
Brooklin, Maine
eye for whisker pole
If you have to buy a fitting for the whisker pole you might want to consider one that is not fixed. On my CD25 the attachment eye was on a track that allowed an up or down adjustment of about 2 or 3 feet. Depending on the cut of your headsail the optimum height of the eye could vary. Good luck.
Greg Phillips
Greg Phillips
- tartansailor
What you need is a 4' track a "Spinnaker Pole Slider" which is used for whisker poles, and a bottom stop, to prevent the slider from falling overboard. The slider is a car with a ring.
Now my CD 25 came with a 3/4" track, but try as I may I cannot find a 3/4" slider. Buy a 1" track and slider, they are much more popular and available.
Viam Inveniam Aut Faciam
- Location: CD 25 #146, Pin-Up and Sabre 36, Grayce, Belhaven, NC
3/4" slider
Dick,
Schaefer stills sells 3/4" slider (part #72-46). You can get those directly from them or for instance here http://www.layline.com/prodinfo.asp?number=S7246
Pierre
CD25, #146
Pierre
CD25, #146
- tartansailor
Spinnaker Slide Car
Thanks Pierre,
I'm fine for jib sheet cars, just need one for a spinnaker pole, difference being 90° orientation of the ring.
