Porthole gaskets
Peter Swiderski
Porthole gaskets
Post by Peter Swiderski »
I need to install new gaskets around my portholes. Any suggestions as to the best type of adhesive I should use?
Peter Swiderski
Ron M.
Post by Ron M. »
3M heavy duty automotive gasket adhesive.Should be available at most auto supply stores. I replaced all my gaskets;ports and hatches 4 yrs. ago and they are holding up fine.
________
Og kush seeds
winthrop fisher
cd 22 "Easy Rider Sr" 84
Post by winthrop fisher »
Hi...starbrite makes one and 3M makes one and there are both good products...winthrop
Steve Bernd
Porthole gaskets
Post by Steve Bernd »
I used DAP rubber cement that you buy at Home Depot for $1.79 with the brush in the bottle. It worked great 5 years ago and I just re-did them all last month with the same stuff. It only needs to be strong enough to keep the gasket in place as the force from the window will provide the seal. Just follow the directions, let the two surfaces dry and stick them together. Only problem is that you have to be careful to get it right the first time because once you stick it down, it wants to stay.
Steve Bernd
CD28 #359 Valhalla
Ventura CA
