Marine Stereo
Marine Stereo
I have a Cape Dory31. I am interested in a stereo system that would include an amplifier that would work off the DC marine battery, 2-3 small speakers and the Apple I -Pod system. This would get rid of the need for CDs and the CD player. Is such a system avaliable? The system would be in the main cabin which isn't that big. Any thoughts?
- Joe CD MS 300
There was a rencent thread on this topic with a variety of suggestions. Do a search on Ipod or the use the link: http://capedory.org/board/viewtopic.php ... light=ipod
iPod
You might try a system that I learned about from The Hull Truth web site (primarily a power boat site- but dont run away yet!) A simple amplifier of whatever power you want to power up your speakers. The iPod connceted to it via a pig tailed set of RCA cables plugged into the iPod & amp. For detailed info you might go to thehulltruth.com and the electronics forum , lots of talk about stereo/iPod setups
Bets,
Greg
Cape Dory 33 PY
'Katey Wren'
Bets,
Greg
Cape Dory 33 PY
'Katey Wren'
"Orion"
Pearson 31
Manitowoc, WI - Contact:
Consider an MP3 Receiver
the Ipod setup can be expensive. A more tolerable solution might be to make sure your receiver can play MP3 disks. If you don't mind the compression (my ears can't tell the difference on a boat anyway) it will allow you to combine up to 10 CDs onto one.
Unless you already own an Ipod....
As for the solution I chose, I went with a Sony CDXF50M w/ XM Radio input and a pair of Dual 4 1/2 in speakers. Between XM Radio and the MP3 ability, I don't plan to have many CD's on board.
Good luck.
Mike
Good luck.
Mike
