I'm almost finished repowering my CD 36 with a Yanmar 3JH4 which replaced the 3JH3. Yanmar does not specify using a flex coupling in the prop shaft, which the original Perkins was equipped with.
Does any one know if Robinhood uses a flex coupling with this engine or it's predecessor in their 36?
Have any other repowers used it because of the short shaft length?
Tom Blanchard
CD 36 repower
CD 36 Buffalo, N.Y.
- Parfait's Provider
berthed Whortonsville, NC
Flex Coupling
Tom,
Parfait was fitted with both a PSS seal and a flexible coupling. There was some question as to whether it would all fit, but engine is well forward in the space and there was room.
Keep on sailing,
Ken Coit, ND7N
CD/36 #84
Parfait
Raleigh, NC
Ken Coit, ND7N
CD/36 #84
Parfait
Raleigh, NC
Flex coupling/shaft log
Sherpa, our 1979 CD36, has a flex coupling between the shaft and the Hurth gear. I've always thought that the flex coupling was important in this installation primarily because we have a solid bronze, one piece shaft log-stuffing box which unlike the the two piece, rubber hose connected version one sees on many boats, probably does not tolerate vibrations or misallignment very much.
This is just a guess based on observation. However, if you have the same one piece shaft log-stuffing box set up on your boat, you may wish to research my opinion further before making a decision either way.
Regards,
Greg
Regards,
Greg
Our 1979 CD36 came with the same one piece design stuffing box that Greg mentioned. When we repowered we replaced that with the common two piece design. We also installed a PSI flexible coupling. My understanding is that the shorter the length of the prop shaft the more important it is to have the coupling and the two piece stuffing box to help absorb and isolate vibration caused by the engine. Our CD's have fairly short prop shafts.
Pat
________
Grape Ape Marijuana Strain
________
Daihatsu copen history
Pat
________
________
