Gauges go crazy on CD 30 - need help!
Erick Frack
Post by Erick Frack »
Yesterday I was cruising along under power (Volvo MD 7) with the tachometer displaying 2,000 RPM. When suddenly, the tach. needle started to swing in 500 RPM arcs. At the same time, the temperature gauge climbed almost into the red, then declined to barely in the green, then back to the red, etc. This continued for the next ten minutes until I reduced power upon arrival at my marina. During the whole time, the throttle was not changed, the sound of the engine never changed, nor did the amount of water exiting through the exhaust change. Any ideas?
Erick Frack
CD 30 Adrianna
Fond du Lac, WI
efrack@execpc.com
patrick carr
Re: Gauges go crazy on CD 30 - need help!
Post by patrick carr »
Erick Frack wrote: Yesterday I was cruising along under power (Volvo MD 7) with the tachometer displaying 2,000 RPM. When suddenly, the tach. needle started to swing in 500 RPM arcs. At the same time, the temperature gauge climbed almost into the red, then declined to barely in the green, then back to the red, etc. This continued for the next ten minutes until I reduced power upon arrival at my marina. During the whole time, the throttle was not changed, the sound of the engine never changed, nor did the amount of water exiting through the exhaust change. Any ideas?Have you recently added any gauges or changed the alternator or added any charging equip? Sounds like your alternator or alt field wire is bad. Does the tach swing more or faster when eng RPM is changed. Let me know.PJC
Erick Frack
CD 30 Adrianna
Fond du Lac, WI
pierat@msn.com
