Replacing Spartan SeaCocks with Groco - some questions
Carl Thunberg
Re: Replacing Spartan SeaCocks with Groco - some questions
Post by Carl Thunberg »
I replaced my raw water seacock over the last two weekends. In case anyone wondered what grows behind a bronze pre-screen take a look at this first photo. This just seems like a really bad idea to have a permanent pre-screen (no hinge). The growth extended to the through-hull, so I had to resort to a grinder to grind it off. Needless to say, the finished installation has a conventional through-hull without a pre-screen.
Bronze Screen.jpg (1.06 MiB) Viewed 1333 times
Through Hull Removal.jpg (1.33 MiB) Viewed 1333 times
Finished Installation.jpg (886.06 KiB) Viewed 1333 times
Sir Isaac Newton
Good job! Correct. No screens for intakes. That is an old technique no longer recommended.
keneasley
Post by keneasley »
Interesting post about the marine growth at the raw water intake.
I did not have those problems.
I was rather surprised when I removed the strainer and there was no marine growth at all.
I had always painted the outside of the strainer with ablative antifouling paint but had never removed
the strainer to paint.
When I removed the strainer in order to replace the thru-hull I saw a good coating of antifouling paint still there and no growth.
After I replaced the thru-hull and seacock I attached a hinged strainer to facilitate future maintenance.
I attached it with 4200 onto the bare gelcoat and then painted inside and out with antifouling paint.
Ken Easley
Intrepid 9 Meter - Felicity
Southport Harbor, Connecticut
