To clarify a bit, I was asking about through bolting the stanchion to the base.
Most of the stress would be lateral so I am not sure the stanchions would pop out even if they were not fastened to the bases but it is still a good thing, Steve.
Lifeline replacement
- David Morton
Re: Lifeline replacement
I like the idea of bolting the stachions thru the base. At least you are able to see what is going on at the business end of the bolt rather than it being hidden inside the stanchion. Loose and missing nuts should be obvious at a glance and easier to fix. Downside is it means removing metal from base itself, but seems negligible to me.
David
David
You could probably drill them in place with a good sharp bit and an angle drill. If you removed the stanchions and drilled them on a press, at home, the holes would help align the holes in the base. I have never had a problem with elastic stop nuts getting loose, even if they are not tightened down.
I just wonder why they are not done this way, in the first place, Steve.
The stanchions on Mariah were done this way and it worked fine.Steve Laume wrote:To clarify a bit, I was asking about through bolting the stanchion to the base.
