The pump handle on my CD-28 head has been sticking and hard to work. I didn't want to pump through some motor oil as some people do (polluting) so I pumped in a bottle of salad oil. Everything works smoothly now. - Joe Brown, "Caprice," Rockport, Maine
joebrown@mint.net
Oil on Troubled Heads
Re: Oil on Troubled Heads
You don't need to use a whole bottle of vegetable oil; an ounce or two is plenty!
JSeebacher@worldnet.att.net
W&C markets "Head Lube" and it works quite well. I have also used "LESTOIL" which seems similiar to the Head Lube, but is much cheaper (and you can use it to clean fiberglass).
thebobers@erols.com
thebobers@erols.com
