In the spring I place the stanchions back in the stanchion bases and tighten the little set screw to "snug up" the stanchions in the bases. These are very small screws that go thru a threaded hole in the stanchion base and then into a threaded hole in the stanchion itself. This, to me anyway, is a pretty flimsy design, as it is not uncommon for the thread to strip even if you are careful, when you tighten it up.
The screw, even when turning in a stripped thread, will prevent the stanchion from pulling out of the stanchion base, but because the screw is no longer able to be tightened, the stanchion will wobble in the base. Not a monumental problem but it bothers me!
I suppose the answer might be to drill a slightly larger hole in the existing holes and then tap the new holes to accept the larger diameter screw. But that cure would also be susceptible to stripping in future years.
Has anyone drilled clean through to the other side of the stanchion base and perhaps used a long bolt, two washers and a nut (through bolting, if you will) to try and make a more secure set up? Any other recommendations for permanently curing the wobbly stanchion, short of shoving shims down between the stanchion and stanchion base, would be appreciated.
Thanks!
