zinc for volvo MD7A/B engine ???????
cutt
Post by cutt »
Does anyone know if the volvo diesel MD7A/B engine has a sacrificial zinc ? I cannot find any.
paul
cutt@netcom.com
Tad McDonald
Re: zinc for volvo MD7A/B engine ???????
Post by Tad McDonald »
I asked a mechanic about this at a diesel seminar. He said there isn't one. There is one in the water lift muffler.
tadmcdonald@worldnet.att.net
cutt
Post by cutt »
Tad McDonald wrote: I asked a mechanic about this at a diesel seminar. He said there isn't one. There is one in the water lift muffler.
do you know where the one in water lift muffler is ?
John
No zinc, add one
Post by John »
cutt wrote: Does anyone know if the volvo diesel MD7A/B engine has a sacrificial zinc ? I cannot find any.
paul
There isn't one. I added a zinc holder to the raw water inlet line to make up for it. There is also one (small) in the cooling water heat exchanger. There wasn't one in the original stainless waterlift muffler from the factory. I have since replaced that with a fiberglass waterlift.
cutt
Re: No zinc, add one - HOW ?????
Post by cutt »
I wonder how to add a zinc holder ? Does west marine sell a zinc holder ? Where is it added ?
thanks,
paul
paul
Mikie Q.
Post by Mikie Q. »
cutt wrote: do you know where the one in water lift muffler is ?
In my 7B the zinc is in the inboard lower end of the water lift muffler. Not a fun job on a 28 CD.
Mikie Q.
mikieq@erols.com
John
Sendure
Post by John »
cutt wrote: I wonder how to add a zinc holder ? Does west marine sell a zinc holder ? Where is it added ?
thanks,
paul
You can order a zinc pencil in-line holder made by Sendure. They make them in various sizes to fit different hose ID's and NPT pipe threads. Install it in the raw water feed hose between the raw water strainer and the engine. The zinc holder has a terminal on it for connection of a ground wire. Connect the ground wire to your common ground point. See below for Sendure address and info.
SENDURE
6785 N.W. 17th Ave.
Ft. Lauderdale, Fl. 33309
PH: 954/973-1260
FAX: 954/968-7213
E-mail: sen-dure@worldnet.att.net
Web site: www.sen-dure.com
