Prop Size ( Dia, Pitch and # of Blades) for CD33s & 330s
If you have a CD33 or CD330 with a 3000 RPM 24/25HP engine, and you are using a fixed blade propeller, please tell me what size prop you are using AND if you happy with it.
Neil Kozlowski
Ariel CD330 #146
Ariel CD330 #146
CD33 Prop Size
Hi Neil,
I'm using a 14X10 on my 33, powered by a Yanmar 3GM30F. I'm cruising at 2600 rpm, with a 2.3:1 gearbox. I'm very happy with the configuration.
At the moment, I'm on the hard in Deale, working on changing my cutlass bearing. Lots of fun!
Jim Evans
- M. R. Bober
Neil,
We should have spoken @ Groundhog Day. RESPITE started out w/ a 2 blade 14x10. When I opted for a third blade, conventional wisdom called for 14x8 (keep the diameter & drop 2" off the pitch), but the prop shop owner--knowledgeable old timer--suggested that my two blade (a Columbia) was high chord("heavy chord"??) and a drop of only 1" might be possible.
His rule of thumb was a diesel engine in forward gear should be able to attain a speed within 100 rpm of the no load speed. I found the 3 blade 14x9 is a bit too much for the Universal M-30 to push (i.e. cannot attain high enough rpm in gear, and she starts to run hotter than I like).
I'm trying to find a prop shop that can drop the pitch the second inch. Also RESPITE'S M-30 was one of those with the 2 inch heat exchanger. I bought Ed Haley's 3 inch exchanger, which I will install after launch. That should solve the warm running, but unforunately won't add a few hundred rpm.
Every best wish,
Mitchell Bober
Sunny Annapolis (home of PROPer sailors), MD
Every best wish,
Mitchell Bober
CDSOA Founding Member
And I'm Using a 3 blade prop
Neil - I forgot to tell you I'm using a 3 blade prop; a 14X10.
Jim Evans
- Zeida Cecilia-Mendez
Neil, Bandolera II has a Michigan prop 14 RH 13 wo 12 (right turning) three blade. My Universal Model 30 #5424 cruises happily at 2200 rpm's without overheating and will go up to 2500 rpm's but if I stay for too long at the higher speeds, it will tend to get hot. But then I reduce speed somewhat -back to the 20's- and the engine immediately cools off. And that is still with my old 2" heat exchanger.
I had tried to buy Ed Haley's 3" heat exchanger, but I was pre-empted by M.Bober
Over all, my 3 blade prop works very well.
Zeida
Thank You all for the inputs
Thanks all for the input. I'm using a 14 Dia by 10 Pitch, 3 blade michigan wheel prop. I was having a few problems so I wanted to see what the fleet was using to see if my prop was in the ball park. I have concluded it is! Thanks again.
Neil Kozlowski
Ariel CD330 #146
Ariel CD330 #146
