Volvo engine/transmission
Bob Duffey
Post by Bob Duffey »
Hi again
In further looking I just found out that the transmission on the TAMD 40B Volvo engine in the boat I am looking at is the Volvo MS3c transmission, not the other that has been mentioned-is anyone aware of any problems with this tranmssion or the engine/tranmission combination?
Bob
RDuffey656@aol.com
john edwards
Re: Volvo engine/transmission
Post by john edwards »
Bob:
You ought to check w/ several well regarded Volvo dealers and inquire.
On ours we have the turbo 200 hooked up to the MS4A which is supposed to be the devil child.
However, all of the Volvo dealers I spoke w/ claimed that if used and maintained properly its a good transmission. They said the bad rep came mostly from twin engined "high performance" fishing boats, like rampages and black fins where these sport fisherman smash around the boat in their eager/desperate efforts to land their fish; jamming it into reverse and backing down on the fish... and so on.
So, I'd check w/ a few reputable volvo folks.
Good luck
JE
CD28FB
#164
Bob Duffey wrote: Hi again
Bob
je1449@aol.com
Bob Duffey
Thanks John
I did just that this afternoon, spoke with a highly regarded Volvoa machanic down here in Florida. He pretty much echoed what you said, and also said that the MS3c was a fairly problem free transmission in his experience.
He also sais that TAMD 40B is a good engine but wanred that it was becoming fucntionally obsolete, and parts would become very expensive for the engine, although supply of parts should not be a problem. He said that biggest problem with these engines was in the colling system, esspecially the heat exchanger.
Thanks again!
Bob
john edwards wrote: Bob:
Good luck
JE
CD28FB
#164
Bob
RDuffey656@aol.com
john edwards
Hi Bob:
I think with any engine used in salt water, the cooling systems need extra attention. My feeling is to always do preventative maintenance, as Ma nature is always ready to give us a run, why not try to control those few things that we can, by good maintenance.
All boat parts are expensive, but Volvo is truly sans humility
Best of luck
JE
Bob Duffey wrote: Thanks John
Thanks again!
Bob
Good luck
JE
CD28FB
#164
Bob
je1449@aol.com
john walden
Post by john walden »
I just replaced the exhaust elbow, re-conditioned the oil cooler, heat exchanger, and aftercooler at 3000 hours. I have a TAMD 40B. First time for this. Replace water pump impeller every other season. I had transmission problem the first year , but Volvo paid for the repairs. Cone clutch was slipping.
