CD28 Powerboat Window Frame Corrosion
Roy Tapio
Post by Roy Tapio »
Have a 1989 flybridge cruiser that has aluminum window frame corrosion. Seems like this is a common problem. Has anyone found a good solution or repair for this?
Are the window frames readily removable for refinishing?
What is involved in disassembly?
What should be used to clean, prime and refinish the frames?
Roy
r.tapio@worldnet.att.net
Walt Bilofsky
Re: CD28 Powerboat Window Frame Corrosion
Post by Walt Bilofsky »
Roy -
Roy Tapio wrote: Are the window frames readily removable for refinishing?
See <a href="http://www.toolworks.com/cgi-bin/tw/wwb ... &444">this post from the archives</a> for the way I removed the windows from my CD 30 powerboat.
- Walt Bilofsky
bilofsky@toolworks.com
Hobbster
Post by Hobbster »
Roy: The frames are hard (not impossible) to remove. You can have then painted with Awlgrip. Awlgrip has a step by step process to paint aluminum. Most boat co.have gone to this.
Glen
gle@hobbymarine.com
