Have a 1989 flybridge cruiser that has aluminum window frame corrosion. Seems like this is a common problem. Has anyone found a good solution or repair for this?
Are the window frames readily removable for refinishing?
What is involved in disassembly?
What should be used to clean, prime and refinish the frames?
Roy
r.tapio@worldnet.att.net
CD28 Powerboat Window Frame Corrosion
Re: CD28 Powerboat Window Frame Corrosion
Roy -
- Walt Bilofsky
bilofsky@toolworks.com
See <a href="http://www.toolworks.com/cgi-bin/tw/wwb ... &444">this post from the archives</a> for the way I removed the windows from my CD 30 powerboat.Roy Tapio wrote: Are the window frames readily removable for refinishing?
- Walt Bilofsky
Roy: The frames are hard (not impossible) to remove. You can have then painted with Awlgrip. Awlgrip has a step by step process to paint aluminum. Most boat co.have gone to this.
Glen
gle@hobbymarine.com
Glen
gle@hobbymarine.com
