Does anyone know how the ignition system on the Force 10 ranges is powered? Am I looking for a blown fuse or a circuit breaker I haven't flipped or what? Thus far we are using a fire stick, but it would be so much easier....
Ken
parfait@nc.rr.com
Force 10 range
Re: Force 10 range
Well ken I'm not positive on this one but I think it may utilize a piezo electric igniter. You know, the same type that is on a propane barbecue. They don't use any source of supplied electricity. I think they are a friction sort of gadget and you can't fix them you have to replace them. You should be able to remove the igniter from the stove /oven and determine for sure what it is, or what the hey, give Force 10 a quick call. Maybe someone else has more insight on this.Ken Coit wrote: Does anyone know how the ignition system on the Force 10 ranges is powered? Am I looking for a blown fuse or a circuit breaker I haven't flipped or what? Thus far we are using a fire stick, but it would be so much easier....
Ken
Re: Force 10 range
Ken,
If my memory is correct there is a battery underneath the stove-i just can't remember what side it is on or the type.
Larry M
cd 33 dolce
lmace@gt.com
Larry M
cd 33 dolce
Ken
lmace@gt.com
Re: Force 10 range
Ken,
The Force 10 range/oven on my boat has a AA battery to power the burner igniters. The battery is on the under side of the oven area on the right. I have twice had a failure of the switch which activates the igniter.
Yours for better igniting,
Joe Mac Phee
S/V Iolanthe
CD-30 K
jvmacphee@aol.com
Joe Mac Phee
S/V Iolanthe
CD-30 K
jvmacphee@aol.com
Re: Force 10 range
Thanks for the clues. We are off to the boat and I will be looking for that battery!
Ken
parfait@nc.rr.com
Ken
Ken
parfait@nc.rr.com
Re: Force 10 range
And the battery is found. Unfortunately, the holder seems to have become disconnected from its ground lead, but that will be quickly fixed. Thanks to everyone!
Ken
parfait@nc.rr.com
Ken
Ken Coit wrote: Thanks for the clues. We are off to the boat and I will be looking for that battery!
Ken
Ken
parfait@nc.rr.com
