Port Light Gaskets
Port Light Gaskets
When I bought my CD28 it did not have gaskets on the ports. I have owned it for 22+ years and never knew until recently that the ports were supposed to have gaskets. They would leak sometimes but simply tightening them would resolve the problem.
After realizing that they were supposed to have gaskets I purchased the material (1/2-inch EPDM) from McMaster-Carr for installation. While doing some dry fitting of the gaskets I tried closing the port. I found that it is almost impossible to close the port with the gasket installed.
So I just wanted to see if this is the same condition that others have experienced when installing new gasket material?
Re: Port Light Gaskets
I assume you removed the old compressed gaskets from the channel first and cleaned down to bare metal.
Assuming that to be the case, on my windows, the glass and the frame are not as parallel as one might hope, resulting in more compression of the gasket at the top near the hinges than the bottom near the dogs. If you tighten them gently at first, the top is tight while the bottom is still loose enough to leak. However, after several days left in this state, the top compresses and you can tighten them some more which seals uniformly.
Steve
Steve
Belmont Harbor, Chicago IL
Did you order the soft or the standard neoprene cord stock? I made the mistake of ordering the standard earlier this year and had the same issue. The soft is what you want. Upon closing the ports the first time it will be an exceptionally tight fit due to the thickness at the top but they'll compress a little and hold a flatter shape once you get them closed the first time. (FWIW after my error of ordering the standard I didn't in fact order the soft but rather just bought them premade through Spartan, not wanting to potentially screw up a second time. It was apparent however that Spartan uses the 1/2 soft to make them.)
Here's the link for the soft:
https://www.mcmaster.com/neoprene-rubbe ... ord-stock/
Craig Curtis
1990 CD 40 "Coalescence"
Belmont Harbor
Chicago, IL
Belmont Harbor
Chicago, IL
Just curious... has anyone tried using 7/16 instead of 1/2? Seems like it might work better top & bottom.Craig Curtis wrote: It was apparent however that Spartan uses the 1/2 soft to make them.)
- S/V Ethan Grey
I replaced all of mine with McMaster-Carr 8605K44 Ultra-Weather-Resistant EPDM Foam Cord, 1/2" Diameter, 100 Feet and haven’t had a leak yet. The hatches close just fine.
@mgphl52, I have some spare, if you need some.
-david
-david
David
S/V Ethan Grey
1981 CD 30C, Hull #199
Niceville, FL
CDSOA# 1947
S/V Ethan Grey
Niceville, FL
CDSOA# 1947
We got the pre-made gaskets from Spartan and had no issue.Bryce wrote:When I bought my CD28 it did not have gaskets on the ports. I have owned it for 22+ years and never knew until recently that the ports were supposed to have gaskets. They would leak sometimes but simply tightening them would resolve the problem.
Danielle Elizabeth
CD30
Danielle Elizabeth
CD30
- Cathy Monaghan
Hi Bryce,
What year is your CD28?
The older CD28s have plastic ports and the newer CD28s have bronze ports. Are your ports plastic or bronze?
- Cathy
- Cathy
CDSOA Associate Member #265
Greenline 39 Electra
Rahway, NJ
Raritan Bay
Rahway, NJ
Raritan Bay
My CD is a 1981 and has the bronze ports. It might be that the chord I purchased was too stiff. I will try the soft version from McMaster-Carr to see if that makes a difference. Thank you all for your responses.
- S/V Ethan Grey
Bryce, if you want, shoot me your address and I’ll send you enough for a port light. Then you can decide if it works better for you. -david
David
S/V Ethan Grey
Niceville, FL
CDSOA# 1947
S/V Ethan Grey
Niceville, FL
CDSOA# 1947
What glue have you guys used for the gaskets? I used Testers model airplane cement on the recommendation of Spartan and a couple of the gaskets have come unglued.
You might want to try Barge All Purpose Cement.
I have found Weldwood Contact Cement works well. I just used some to replace a gasket and the cement was still fine after several years so it apparently has a long shelf life after opening.
