CD25D bimini
Moderator: bobdugan
CD25D bimini
The dodger on my boat barely covers the hatch way. I will attempt to fabricate a bimini that will cover more of the cockpit but stay below the boom. I measured the tubing diameter to be .875” and know that diameter is used for the common 3/4” copper tubing that is very bendable and cheap from the building and plumbing suppliers.
I would much prefer to have this in 316 SS but this presents a problem when I form the tubing to fit my boat and boom height. Another problem is the fittings to attach the bow to the existing hardware. In my quick look, I was able to find “Sea Dog” hardware in SS but it’s 1” diameter. Is their a supplier that makes .875” diameter hardware? I’m sure there must be because I have it on the boat.
I’m less concerned about the Sunbrella material because I have a local upholsterer that can sew up what I need and modify the dodger to attach the bimini.
Any help with this project is greatly appreciated.
Tom
Tom
Re: CD25D bimini
Hello,
Why not make an awning which goes over the boom? Three straight tubes, it rolls up and deploys quickly. You can stand under it if the boom is set high enough.
Just a thought.
Steve
Just a thought.
Steve
Steve
Re: CD25D bimini
Lots of folks do just that. They usually sue PVC tubes that will bend a bit so that any rain will run off the sides.
- Joe Myerson
Re: CD25D bimini
That's what I have on my 25D. The PO's wife made it. It even has roll-up sides.
I think a bimini would require raising the boom. I don't know if that would compromise performance.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
Re: CD25D bimini
steveg wrote:Hello,
Just a thought.
Steve
Great thought!
Some PVC connectors and some blue tarp just to see how well it stays in place.
Cheap proof of concept!
Re: CD25D bimini
I used stainless tubes, with wood dowels stuck into the ends. Screwed stainless eye bolt in and they were good. Having some adjustable straps is a good idea also. It is nice having the height under the awning. If you have a dodger (some call it a spray hood) it is even cozy on a wet and or windy day.
Steve
Re: CD25D bimini
We made one for our CD25 and the thing I added was I cut the tubes in half. Glued a coupling to one side and ran bungee cord the whole length under tension. This allowed me to pull it apart into a small package for storing without having to worry about losing parts.
Chris Anderheggen
CD25 "Windsong"
Catalina 30 "Kestrel"
Catalina 387 " Parrot Cay"
Credo quia absurdum
CD25 "Windsong"
Credo quia absurdum
Re: CD25D bimini
Thought I sent these pics of my 25d Bimini.
Re: CD25D bimini
Thanks Frank. That looks great!
What did you use for tubing and did you bend the tubing yourself?
Re: CD25D bimini
Ma’am a,
I used 1”,stainless and had the fabrication done at a local canvas shop . They suggested aluminum but I wanted a durable product that I could grab hold of moving around the deck.
Suggest doing a mock up to develop dimensions that work and connection points, I just used electric conduit and did that bending myself.
Did raise the boom 6” to provide more clearance
Re: CD25D bimini
Sir, sorry about the spellcheck!
I did find my measurements for the Bimini frame . Happy to,send via email or pm.
Re: CD25D bimini
That would be great Frank. I've got a tubing bender but I'm not sure it will handle 1" tubing.
I think I'd like to use Seadog fittings and maybe mock up with copper tubing but that might be a waste since it will be used for just setting the bimini up. I also considered using PVC heated up with the torch to play with the shape. I'm not sure how much bend I can put in it before it collapses. I may try it tomorrow.
Your measurements would save a lot of trial and error. Also, I thought if I could make a jig with the tubing in the proper place, I could bring it to my upholstery shop and get him to fabricate the top out of Sunbrella.
Tom
Tom
Re: CD25D bimini
Rough measures 25d Bimini supports
Re: CD25D bimini
For quite some time, I've wanted to add a Bimini. Don't have head room under boom but talked to a sailmaker about the possibility/feasibility of having 6" to 12" cut off the bottom of the mainsail. He didn't think it would have a serious affect on performance. Im still uncertain though.
Cliff
― André Gide
― André Gide
- tjr818
Re: CD25D bimini
You probably do not have to cut the entire foot of the sail. We just cut 11" off at the clew and tapered the foot down toward the tack, that way the gooseneck does not have to be repositioned. Draw it up and see if that would work for you.
