I have recently purchased a Typhoon. On inspection of the spreaders I noticed that the tips (where the shrouds insert) have some free-play between them and the spreader tube. Is this to be expected, or will I need to replace the spreaders? Thanks
Craig
cnspsych@aol.com
Typhoon spreader tip
Re: Typhoon spreader tip
It's a pretty basic set up. Mine just has a kotter pin holding the shroud in place in the spreader tube. It locks down though when you prpoerly tension the rig.Craig wrote: I have recently purchased a Typhoon. On inspection of the spreaders I noticed that the tips (where the shrouds insert) have some free-play between them and the spreader tube. Is this to be expected, or will I need to replace the spreaders? Thanks
Craig
Marino Curati
Ty #74 Snug
Cleveland
mcurati@vision-design-inc.com
