Ready for the bugs!
- David Morton
Ready for the bugs!
I am no carpenter. In fact, this little screen door project, given the asymmetry of the companionway opening, drove me nuts! But I got it done... and it works!
Re: Ready for the bugs!
David, that's a beauty. Looks professional to me
That's the fun (and challenge) of ship's carpentry. Bevels, radiae, etc. Anyone can build right angles, you got it done. Nice job!
Rich W.
s/v Sadie
CD Typhoon #858
s/v Azure Leizure
IP 350 #120
Tiverton, RI
s/v Sadie
CD Typhoon #858
s/v Azure Leizure
IP 350 #120
Tiverton, RI
If that is the work of someone who says they are "no carpenter" then I'll hire a "no carpenter" any day.
The screen enclosure looks beautiful Dave. Well done
Very nice, looks high end.
We got tired of the gnats getting through the velcro'd on screen in front hatch. Used a sheer curtain, a sewing needle and an old soft piece of rope. So far it works well, also we actually seem to get more air down below. It's a "prototype" that has more or less become permanent, so please disregard the duct tape.
- Forward screen
- image.jpg (1.07 MiB) Viewed 856 times
Steve
Pleasant Journey, Morgan 35
Previously:
'85 CD 26, Hull No. 30
'74 Typhoon Hull No. 789
Previously:
- David Morton
Thank you all for your kind and encouraging comments. I guess fishing for compliments really works!!
Please pardon my rude question. I love the hatch screen there, but what is the steel looking pipe just aft of the mast? It looks different. Just curious.
Vincent, I was wondering the same about that pipe!
Skeep
- David Morton
My guess is it is a conduit for mast wiring to the cabin.what is the steel looking pipe just aft of the mast? It looks different. Just curious.
Steve?
It is a 316 stainless steel gooseneck for the mast wiring. Regrettably, a 6 month search for a reasonably priced, pre-made gooseneck like those common in Europe proved unsuccessful. So I made one using materials from McMaster-Carr. One advantage of this gooseneck over the prefab's is that it is strong as hell and can be used as an extra handhold. I keep a small bungie cord around the mast and the opening of the gooseneck to keep the jib sheets from getting hung up (gap of about 3/8 - 1/2 inch). Also, the opening of the gooseneck is sealed from spray/bugs by shoving a small sponge up into and around the wires. You can see the gooseneck better in my project postings from last year.
I did not want to go with a gland type seal on the deck because 1) why fight water & gravity when you don't have to, 2) I've always felt that a lot of maintenance/upgrades/repairs don't happen or get seriously delayed as a result of not "wanting" to mess with gland type seals once they are in place and 3) every maintenance/upgrade/repair task involving a gland type seal is just an invitation for a leak somewhere down the road.
I'll probably upgrade it to a nicer looking premade unit down the road when I get some serious deck fiberglass work done. I've recently met a fellow sailor through work that is based in the Netherlands. Goosenecks are used commonly there and are much less expensive.
Steve
Previously:
Previously:
