Typhoon Doohickey
casampson
Typhoon Doohickey
Post by casampson »
Greetings ladies and gentlemen of the the forum:
I'm having trouble removing the doohickey from the thingamabob on my 1977 Cape Dory Typhoon. I've got to remove and replace it before I launch on May 30th. Any advice would be appreciated.
casampson
Re: Typhoon Doohickey
It might be best to consult a thingamabob specialist to ensure you don't risk damage to your doohickey. :roll:
Joe M
Location: 1984 CD Typhoon "Itilldoo" & CD10 No.315 Cape May, NJ
Post by Joe M »
Typically I use a Whatsit to loosen the Doohickey just a smidge before tapping the Thingamabob with a Wacker. If that doesn't work pry it off with a Whatchamacallit but be careful not to strip the left side Gizmo.
ariasis
Post by ariasis »
I like to use that spray stuff with red straw when things get really jammed.
Sincerely,
Chris B.
Dick Villamil
Post by Dick Villamil »
Just make sure that you use the port doohicky instead of the starboard one - they turn opposite each other.
casampson
Post by casampson »
Thanks for all the good advice so far. I thought I'd add a photo to help illustrate my dilemma. This is a photo of a doohickey that I found on the web. This one has obviously already been removed from the thingamabob. I'd take a picture of mine, but my camera isn't working. Plus, I'm just too lazy to crawl in there with my bad back and all.
If you would have locked the doohickey while under way you probably wouldn't have this problem :roll:
Oswego John
Post by Oswego John »
Yea Verily,
It has been a long, hard winter. Slowly, one by one, the northern captains are finally beginning to thaw out and manifest themselves. :D :D
"June is bustin' out all over".
Tiller John :wink:
"If I rest, I rust"
Voting Member #490
rjnale
Location: 1982 CD Typhoon Daysailer "Typhoon Mary" Hull #97 model K Syracuse NY
Post by rjnale »
Thank you for posting the picture. Try a left handed turney thing with the godunk that clicks when you pump the handle.
I need help too! My marina guy called and said he wanted to rotate my running lights, something about helping with downwind performance or his investment performance, I don't know our phone connection was bad. I trust the guy because last year when storing the boat he pointed out the stern light was pumping oil and fixed it for $50 bucks! That could have been a mess going unchecked!
Happy Holiday Weekend all!
winthrop fisher
cd 22 "Easy Rider Sr" 84
Post by winthrop fisher »
left right :oops: right left :oops:
:idea: next time ask him what is smoking :wink: :roll:
casampson
Post by casampson »
Mr. Fisher:
Did you mean to say: "Next time ask him what he is smoking"?
casampson
Dick Villamil
Big question: Should you lock the doohickey while sailing, put it is reverse or let it spin> :D
Oswego John
Can't really say for sure. The early models of the Ty didn't have Doohickeys. They came with something called a Hickdookey. They did the job up to a point. Sure, you could go downhill okay with them but going uphill was a bugger. The Doohickey was a great improvement.
"If I rest, I rust"
Voting Member #490
pjust
Post by pjust »
It might be simplest to just replace the Doohickey. There's a new electronic version that West Marine is selling for only $899.95. Or you can get it in bronze from J.M. Reineck & Sons for only $1299.99 if you want the traditional look.
Peter Just
Typhoon Weekender #602, Dolcetto, Spruce Head, ME
"It is not with impunity that we go out on the water, but with sufferance." - Roger C. Taylor
winthrop fisher
OJ, you been doing it all wrong, :oops:
how's everthing going these days :?:
