Ladder for CD22
Ginny
Ladder for CD22
Post by Ginny »
I am a proud new owner of a CD22 and new to sailing also, and need a rigid ladder to get back into boat. Where do I find one.
pecks@cheerful.com
Joe Sankey
Re: Ladder for CD22
Post by Joe Sankey »
Ginny:
We bought a 36" ladder from West Marine for our 22. It works fine, although like any similar ladder the rungs are not too comfortable. It is fairly easy to mount one on the 22 due to the lazzarette.
Joe
Ginny wrote: I am a proud new owner of a CD22 and new to sailing also, and need a rigid ladder to get back into boat. Where do I find one.
sankey@gulftel.com
Ginny
Re: Ladder for CD22
Post by Ginny »
Joe Sankey wrote: Ginny:
Joe
Joe,
Thanks. Now can you tell me whick ladder it was and if it fit into the brackets already on the boat or did it fit over the side.
Ginny
Pecks @cheerful.com
Joe Sankey
Re: Ladder for CD22
Joe
Joe,
Ginny
Ginny:
The ladder we bought is referred to as WM Ladder #115550 on West Marine's web site. The mounting pads on the photo look the same as ours did. However, we bought ours several years ago, and the same ladder in the stores now may not have exactly the same mounting brackets, although the ladder appears to be the same. We backed up the mounts with 1/4" ext. plywood and fender washers.
If you have brackets already I could only guess what ladder the boat may have had. I'd measure the distance between them; the distance from the waterline. These will help you find a replacement that might work, although it would appear to me that a new ladder would come with brackets. Good luck.
Joe
sankey@gulftel.cm
Dan H.
Re: Ladder for CD22
Post by Dan H. »
Ginny,
I just priced the same for a CD25 from the original manufacturer, Ocean Engineering. It was about $325.00 You can contact them through the link on this site or directly at www.boatrails.com
djhhan@aol.com
