How to attach boom to mast
Hi,
I'm a very seasoned boater but not necessarily a sailor (yet). I do know how to sail and sailed a lot as a teen.
Anyways, I was given a 1966 typhoon that had been sitting in a friend's driveway for 20 years since
he took it out of the water. I had to replace the floor because it was rotten. I have redone all the wood
and it looks great, but I can't figure out how to attach the boom to the mast.
The end of the boom looks has a piece that looks like it would side on a 1/4" rod but I don't see any such piece in the mast. The boom also has a stainless horseshoe shaped connector attached that is about 2". This is the type of connector that you would see on mooring chain either to connect to the mooring on the bottom of the chain or to the rope when the chain
comes through the mooring ball. Obviously it is much smaller.
I'm completely stumpted as to how to connect the boom. If anyone can provide some guidance that would be
a big help. Thank you.
I'll be putting the boat in the Sandwich Marina on Cape Cod. It's at the East end of the Cape Cod Canal.
john
john
Re: How to attach boom to mast
Any chance you could post a picture?
My boom has a stainless slug that fits in the sail slot on the mast.
If you look on the Rig Rite website they show a variety of gooseneck slides: http://www.rigrite.com/Spars/SparParts/ ... lides.html
Here is a link to how mine goes together. But your description does not sound the same as mine. http://bristol-blue.blogspot.com/2014/0 ... gging.html. If you have pictures post it your boat at a 66 is quite a bit older than my 78.
Sincerely,
Chris B.
Chris B.
Sounds like you have a piece missing. If I recall correctly, the 1/4" fitting should receive a pin and serve as the pivot point. The piece coming out of boom is likely a square rod. The missing piece would have a collar that fits over rod in mast to receive pivot pin and on other end a slug or partial rod that fits mainsail track on mast.
A picture would help, especially for ring.
Steve
Pleasant Journey, Morgan 35
Previously:
'85 CD 26, Hull No. 30
'74 Typhoon Hull No. 789
Previously:
Also, sail stops are handy to put in above and below that cylinder that goes inside the mast. The stops keep the sleds on the sail from popping out, and also keep boom from jumping out of the hole where you inserted the cylinder.
Best,
Tom Ricks
Best,
Tom Ricks
Hi,
thank you all. I was missing a part which we got from the recommended web site. $39 and we are up and sailing.
john
john
Super John. Hope to see some pictures of your boat out on the lake soon!
Sincerely,
Chris B.
Chris B.
- Cathy Monaghan
Gooseneck assembly and parts for Typhoon...
This Rig-Rite page shows both the mast section and the gooseneck assembly and parts:
http://www.rigrite.com/Spars/Spartan_Sp ... _boom.html
CDSOA Associate Member #265
Greenline 39 Electra
Rahway, NJ
Raritan Bay
Rahway, NJ
Raritan Bay
Cathy, thanks for that link. For all the searching I've done on RigRite, I've never managed to see that page! Everything in one place is terrific.
Skeep
