crapper
- Jim Cornwell
Re: crapper
There must be a backstory to this comment. The only way to check obstruction of the through-hull that I can think of would be to disconnect hose from seacock (or head) and crack the valve briefly to verify flow of seawater. Any other way?
Re: crapper
There's a broader principle at play here and there are many examples. Do the easy/inexpensive trouble-shooting first, even if going that route is less likely to identify the cause.Stefan wrote:Protip: before you disassemble and reassemble the head, you may want to check whether the thru hull isn't completely obstructed by marine growth...
Re: crapper
You mean like when the mower will not start you should check to see if there is any gas in there?Neil Gordon wrote:There's a broader principle at play here and there are many examples. Do the easy/inexpensive trouble-shooting first, even if going that route is less likely to identify the cause.Stefan wrote:Protip: before you disassemble and reassemble the head, you may want to check whether the thru hull isn't completely obstructed by marine growth...
Sometimes the solution is so obvious that it isn't even considered to be a possible problem, Steve.
Re: crapper
The fellow in the next slip climbed his mast a couple of weeks ago to change a perfectly good light bulb. Perhaps he should have started troubleshooting at the electrical panel or at the base of the mast.Steve Laume wrote:You mean like when the mower will not start you should check to see if there is any gas in there?
Re: crapper
Ockham's Razor
