I went ahead and repainted the cockpit and tried out the Rustoleum marine paint and non skid now available at Lowes:
The battery space provided just enough space for the install and compartment:
I laminated pieces of 1/2 " plywood together with West Marine epoxy then covered the rails with heavy woven fiberglass cloth and epoxy resin. The engine mounts are from a PWC. Additional pieces of hardwood were placed underneath the fiberglass deck of the battery location to secure the L brackets and wood screws that were holding the rails in place. Lots of put the engine in place, take it back out and measure, adjust to get the rails cut the a proper angle to give the propshaft the correct path out to the keel.
Backing plate and valve for raw water intake
here is the hot section of the exhaust and the propshaft outer tube. The water lift muffler pictured is mounted on the opposite side beneath the seat. after the riser section pictured, the black iron pipe runs across and beneath the cockpit floor, connects to the water lift muffler, which finishes with a section of wet exhaust hose that exits the transon through flap covered through hull.
James
