Bottom & Boot Top Paint
Keith
Post by Keith »
Hi All,
I'm starting to think about my first spring launch for "Moon Dance" 30C. I know a bit early since we just got dumped on hear in NE. I want to go with the traditional Brown bottom and Dark Brown boot top. The original owners manual states Rule Industries "Epoxy Cap" (no part #) for the bottom paint and Interlux 246 for the boot top. Since this information is 33 years old. Question #1 - Does anyone know who the current manufacturers of these equivalents are and what the part #'s are? Question #2 - What quantity will I need of each?
Looking forward to those great answers that I am becoming used to.
Keith
Cathy Monaghan
Re: Bottom & Boot Top Paint -- bump...
Post by Cathy Monaghan »
bumped by the webmaster....
CDSOA Associate Member #265
Rahway, NJ
Raritan Bay
jerryaxler
Post by jerryaxler »
Epifanes Dado Brown is pretty close to the original for the boot stripe but it has been impossible to get brown bottom paint in the last few years. I was told by a paint manufacturer that mixing red and black will give an equivalent brown bottom paint, but I have not tried it yet.
Fairwinds and following seas,
Jerry Axler
jbenagh
Salem, MA
Post by jbenagh »
I've used Interlux ACT for bottom paint. It is available in brown from Defender.
Jeff
Guy W. Leslie
Post by Guy W. Leslie »
Keith,
Micron Extra comes in brown although a bit pricey. So far, I've gotten two seasons out of it and may even get a third. I'm in fresh water that may be a bit easier on it. I've used both Epifanes and Rust-Oleum for the boot top. The Rust-Oleum is available at Home Depot and quite inexpensive. Come on spring!!
Guy
bamabratsche
Post by bamabratsche »
x2 on the Interlux ACT. It seemed to be the cheapest brown I could find.
Keith
Post by Keith »
Thanks for all of your responses. I'll look into the Interlux ACT for the bottom and Rust-Oleum for the boot top.
Will Rust-Oleum be ok in salt water?
Do any of you CD30 owners know how much bottom paint I need? 2 qts, 3 qts, 1 gallon?
Keith
Post by Keith »
PS does anyone know why my original post was bumped by the webmaster?
I thought that no response meant that no one loved me anymore. :-)
Kevin_P
Location: Former owner of "Meridian"1977 CD30C #58Milwaukee, WI
Post by Kevin_P »
Keith wrote: Do any of you CD30 owners know how much bottom paint I need? 2 qts, 3 qts, 1 gallon?
I've used a gallon of the Micron Extra for the last 2-3 seasons on my CD30. It's held out pretty well, though last season I was thinning it a bit to finish :). I'd say plan on 2 qts. for a nice full coat.
Kevin Petajan
"Vegvisir" - Young Sun 35
1977 CD30C #58
Milwaukee, WI
jbenagh
Salem, MA
Post by jbenagh »
I forgot to mention: I used about 4 1/2 qts last year of the Interlux ACT to cover my CD30. I may have stretched the first gallon too far and then needed to open on the next one to finish the jackstand spots and the very bottom of the keel on launch day.
No ideas on the bump, sorry.
Jeff
Keith
Post by Keith »
Thanks for the inputs but there seems to be a discrepancy between 2 qts and 4 1/2 qts. I guess I'll by a gallon and see what happens.
Keith wrote:Do any of you CD30 owners know how much bottom paint I need? 2 qts, 3 qts, 1 gallon?
A full bottom coat on a 28 takes about 3/4 of a gallon. 1 gallon should be enough for a 30.
Kevin_P
Post by Kevin_P »
I'd agree that 1 gallon would be a great place to start. The thickness of the paint makes a difference, too with regard to how much you use. I probably keep my coats a little thinner than most, because I'm trying to avoid buildup of the non-ablative paint. At the end of the season it seems that I have the same amount of growth on the bottom, whether I have thick or thin coats of paint so I've been opting for thinner :)
Kevin Petajan
1977 CD30C #58
Milwaukee, WI
Keith
Post by Keith »
thanks Neil and Kevin a gallon it is!
