Corroded Steering Bracket
Olli Wendelin
CD30 Ketch
Charleston, SC
Post by Olli Wendelin »
Hello All,
Does anyone have a photo of the bracket under the worm gear steering on an older CD30? This is a steel bracket in the wheel house in the cockpit. It connects the rudder tube to the back of the cockpit. Mine is rusted away and I will be fabricating a new one out of stainless. Any pictures or dimensions would be appreciated.
Olli Wendelin
Blue Moon
CD30 Ketch
Charleston, SC
Webmaster wrote:In an effort to protect the owner of this posting from spammers, the E-mail address has been modified or deleted from this message by the webmaster. Please see the "i" located at the top of this forum titled:
Sticky: Important...regarding e-mail addresses.....PLEASE READ!
Folks, to contact the person who posted the above message, please click on either the "email" or "pm" button below left.
Everybody, please keep the email address in your message board profile up-to-date so that the email and pm buttons will actually work.
Ron M.
Re: Corroded Steering Bracket
Post by Ron M. »
if you click under 'where to look' above and get into the manuals, on pg.48 of the '78cd25-30 brochure there is a simple drawing of what that bracket looks like from the side elevation. The base was glassed into the hull bottom so you should be able to determine it's width dimension from that evidence. Hopefully what remains of yours will fill in the gaps........better yet maybe someone will measure or photograph theirs.
I removed mine years ago for pedestal conversion. good luck
CD 30c #42
S/V "Bluesails"
+ 41.69989
-70.027199
Olli Wendelin
CD30 Ketch
Charleston, SC
Ron,
I do have the manual you quoted. The picture is more concept than reality. My bracket is bolted to the cockpit aft wall. Also the rudder tube extends almost to the steering gear and is fiberglassed to the bracket.
A few years back I built a new aft bracket (which is glassed to the hull) out of stainless. I have a line drawing of it if anyone is interested.
Carl Thunberg
Post by Carl Thunberg »
Check out this thread from the archives. http://www.capedory.org/board/viewtopic ... 86#p130386 I had the exact same problem on my (former) CD30. The photos were posted using the old HTML method, so the photo link doesn't work any more. I'll fix it when I get the chance. In the meantime, you can cut and paste the link into your browser to see the photos.
Carl
Carl Thunberg
Just noticed worm gear reference
Sorry, I just noticed the reference to worm gear steering. Mine was an Edson pedestal. The thread from the archives won't help you.
