CD10 Repairs
CD10 Repairs
The more I investigate my CD10 (hull #1316) the more I learn! The boat has a hull liner with molded nonskid but the liner has a gap between the hull and the liner. This gap continues to the centerboard trunk and to the main drain hole aft of the center seat. Do I need to caulk this gap to prevent water from getting into it or should I inject epoxy into the gap to seal it off? It doesn't seem to have been caulked in the past but...... Also, what does the centerboard trunk plug look like? I think I may need to make one to keep water from coming up the trunk while trailing the "10" behind my Typhoon. The flotation tanks have drain holes - but no plugs. Is there a source for these plugs? It seems like the winter project may take me into late spring but I am determined to have a finished product by May.
- Numbah134
- Location: CD14 #134 (well, if the paperwork actually follows)
I don't know anything about liners, but as far as I know from the CD14, the drain holes take standard lever-expansion plugs, which pretty much any boat store should stock. You mention the main drain hole in the bottom of the hull - just two more like the plug for that (at least, on the CD14 I have, the holes are the same diameter and would use the same size plug.)
ie, this for $2.79 at Defender:
Just make sure the diameter is correct. Not that defender's web site mentions that detail, but I'm sure they can tell you if you ask, and it probably is.
Cats, Coffee, Chocolate - Vices to live by.
