Recommendations for Depth Gage/Transducer Replacement
- Frank Vernet
My old (original?) DMI depth gauge is no longer visible in any light and I want to replace/upgrade it.
Any favorites out there that fit into the DMI 4" (?) opening?
What about the transducer - is the thru-hull copening compatible with anything else on the market?
Frank
Frank
- M. R. Bober
Frank,
I just replaced the Data Marine instruments on STARVIEW with Raymarine ST60s. They fit the 4" holes. If you are interested in my old instrument head, which may or may not work--the problem may have been in the transducer--I will give it to you.
Mitchell Bober
Sunny Lancaster (where the sun went down hours ago), VA
Mitchell Bober
CDSOA Founding Member
As was discussed here a few weeks ago another option is Moor Electronics. I just replaced the Standard Horizon D45 with one of their units. Fit the existing 4" hole . They have a few transducer options, I have a 3/4"
hole with a fairing block, the long stem bronze transducer worked out just fine.
________
Plymouth Cambridge
________
Plymouth Cambridge
- bottomscraper
Transducers for all makes, new and old
Here is a link to the Moor thread:
http://www.capedory.org/board/viewtopic ... 478d9e387f
Airmar web site (transducers for many makes)
http://www.airmartechnology.com/
Radarsonics web site (also transducers, some long stem that Airmar doesn't have)
http://www.radarsonics.com/
Gemeco (Airmar and Radarsonics Distributer)
http://www.gemeco.com/
Gemeco Catalog (Large PDF but lots of good info here, transducers, cable, tools and other electronics)
http://www.gemeco.com/PDFs/Gemeco%202010%20Catalog.pdf
- Location: "VICKY LEE" CD 27, 1977, Hull #21, Port Townsend, WA
I recently installed the Raymarine bi-data 40 digital read-out display unit on my bulkead and their Depth/Speed/Temp Transducer DST800P-A with their bronze thru-hull fitting. I liked that I only used one hull penetration for all three functions and it turns out this transducer has a wider dead hull rise spread than the others allowing it to compensate for the hull shape without a fairing block.
Cheers Dan O...........
Dan O..............
The tri-ducer replaced the existing paddle wheel speed unit that was located in the floor area of the hanging locker. I replaced the plastic housing with the new bronze thru hull fitting. The tri-ducer comes with a plug so it can be removed from the inside of the boat when the boat is afloat. My boat had two large, round Kenyon depth and speed instruments in the bulkhead that were non-functional. I removed them, glassed over the holes and then drilled a new smaller hole for the bi-data 40 digital head. The tri-ducer wiring runs under the stbd settee and the power comes from the panel. I also removed the old depth tansducer that was bonded to the inside of the hull, located on the stbd side of the engine. The new unit works great, gives trip info, water temp, is easily calibrated, and is a much simpler/cleaner installation.
Dan O..............
