When I purchased my CD30 the staysail boom and staysail forestay had been removed. I would like to get the cutter plan back in action and talked with my local rigger about a new forestay. He went mumbling on about a running backstay. I dismissed it at the time, but have started to wonder if the original plan included a running backstay? Is the rig supported when flying a storm sail from the staysail forestay?
Thanks for your advice and I Look forward to hearing from you.
________
MARIJUANA VAPORIZER
Sloop to cutter again?
- Joe CD MS 300
- JWSutcliffe
Skip is right.......no running backstay on the CD30. On my boat I did add a backing plate to the staysail fitting below deck, they used fender washers and I could see some minor crazing of the liner so, I beefed it up, .
________
Ford c4 transmission
________
