Yanmar YSB8 in 1977 CD27
Steve Ing
Post by Steve Ing »
New to this boat + motor, doe's the motor oil also lube the transmission? Where can I get a manual for a old motor like this?
Thank's if you can help.
CHIPING@TCOL.NET
M. R. Bober
Re: Yanmar YSB8 in 1977 CD27
Post by M. R. Bober »
We used to have a Yanmar 8 (YM??). On that model, and I would expect yours, the engine oil did NOT circulate to the transmission. There was a hex nut (1/2" or larger) on top of the transmission case. The nut is the cap of the dipstick.
Hope this helps.
Mitchell Bober
RESPITE
CD330
thebobers@erols.com
Bob Marsh
Post by Bob Marsh »
I just bought a 1977 CD27 also. I got a manual from Mastry Engine Center in St.Pete. www.mastry.com 727-522-9471.
Bob Marsh
s/v Aquanell
Cd27#51
Dunedin FL
M. R. Bober wrote: We used to have a Yanmar 8 (YM??). On that model, and I would expect yours, the engine oil did NOT circulate to the transmission. There was a hex nut (1/2" or larger) on top of the transmission case. The nut is the cap of the dipstick.
Hope this helps.
Mitchell Bober
RESPITE
CD330
marv brinn
Post by marv brinn »
Bob Marsh wrote: I just bought a 1977 CD27 also. I got a manual from Mastry Engine Center in St.Pete. www.mastry.com 727-522-9471.
Hi I did not see the originating email...where is the boat located??are you familiar with Yanmar engines??I am considering one with gfrozen??????rings...
Bob Marsh wrote:
Bob Marsh
s/v Aquanell
Cd27#51
Dunedin FL
Hope this helps.
Mitchell Bober
RESPITE
CD330
mibrinn@aol.com
Bob Miller
Post by Bob Miller »
Steve Ing wrote: New to this boat + motor, doe's the motor oil also lube the transmission? Where can I get a manual for a old motor like this?
Give Garry Myers a call at Yanmar Diesel America Group, 951 Corporate Grove Drive, Buffalo Grove, Ill. 60089-4508; 847-541-1900 or try
www.yanmar.com. Gary is Technical Advisor to the tech service group.
The engine oil (crankcase) and the transmission oil (gearbox) are separate entities.
- Bob Miller
millerfam5050@worldnet.att.net
Olli Wendelin
Post by Olli Wendelin »
The motor oil and transmission are seperate, with their own dipsticks, but you can use the same type of oil in both. I have a Yanmar YSB-12 on my boat. The manuals for the YSB, YSE, and YSM series are still available from Yanmar. There is an owners manual, parts manual, and service manual.
Olli Wendelin
BLUE MOON
Charleston, SC
wendelin@spawar.navy.mil
