I have a question about the length of the jib sheet(s). I am currently using what I believe is the original Cape Dory 100% jib. I installed new jib sheets (port and starboard). According to the Cape Dory Owner's Manual at page 94 (
Soooo, now I always have a LOT of line in the cockpit. In the sailing I have done so far (on all points of sail), I have never let out more than about 10'-12' of either the port or starboard jib sheet.
I am beginning to think that the 32' measurement in the CD Owner's Manual was for one continuous jib sheet.
I think I could shorten each jib sheet to 20' and it would be more than enough line to adjust the jib in all points of sail.
However, I am a rookie/tadpole sailor and reluctant to start cutting up quality jib sheet lines without getting the benefit of this board's wisdom.
When using the 100% jib on your Typhoon Weekender, what is the length of your jib sheet(s)
Thanks in advance for any and all advise, recommendations, etc.
P.S. I again tried to raise "S/V Bandolera II" while sailing yesterday. I was out about 3 1/2 hours and never got a response.
Zeida, where are you
