Vang for a Cape Dory Typhoon
Vincent Sorrentino
Post by Vincent Sorrentino »
I have a 1976 Typhoon.I was wondering if it will be possible to install a Vang.I am looking for idea's
Vincent Sorrentino
NevisTyphoon
Hull # 47
Spartan Marine
Post by NevisTyphoon »
Poke around Spartan Marine
http://www.jibeho.org/vang.htm
Best Regards,
Chris Thompson
Nevis, West Indies
Greatness is not in where we stand, but in what direction we are moving. We must sail sometimes with the wind and sometimes against it-but sail we must, and not drift, nor lie at anchor
Oliver Wendell Holmes
mgphl52
Easy to make for a Ty!
Post by mgphl52 »
Hi Vincent,
I made one up for my Ty years ago with a couple of Harken triple Bullet blocks. I also left lots and lots of tail on the line. The vang could then be used to easily raise and lower the mast single-handed even in the water. Just attach the vang between the jib halyard and jib tack shackle. Then cleat off the halyard. Now you can stand in the cockpit and bring the mast back by easing out on the vang. Stepping is just the same in reverse. When you do step it alone, you'll realize why I used triple blocks!
Enjoy & Have FUN!
