CD-25 & 2005 Mercury 9.9
Tern About
Lake Superior
Has anyone installed a Mercury 9.9MXL 4-Stroke 2005 in their CD-25? I am considering buying one online, but am not sure it will fit.
mercury outboard
I bought a new mercury 6hp 4- stroke for my cd 25 and fit with no problem. It is plenty of power to get off the mooring and through the mooring field. Even on days when the wind disappears and we motor back to the harbor, it is enough power.
Illegitimus non carborundum
cd 25 outboard
Joe try the archives. There has been plenty of info.there
Tern About
Lake Superior
Thank for the suggestions
Thanks for the suggestions. I did search the archives, but didn't find any info on this specific model of motor. I think I will probably end up buying from a local dealer just in case there is an issue with fitting the motor and can exchange it. Thanks again for taking the time to help me out. till later, Joe
- Roy J.
- Location: The fleet: Auburn CD-25, CD-28 #255 as yet unnamed Marblehead MA
Very unlikely to fit
Unless you modify the well, a 9.9hp 4-stroke of any sort is unlikely to fit in the well of a CD-25. Unless you have particular need for so much power, most of us get by pretty well w 6 to 8hp motors that fit. The 8's that fit are slightly older 2 strokes from Johnson or Yamaha. Some have reported satisfaction with the Yamaha 8hp 2-stroke, which I think is a discontinued model. The key fit issues are height above the mount and size of the powerhead -- can it be turned to help maneuver the boat and can it be operated withthe lazarette hatch closed. Secondary issue many of us deal with is the motor weight. Over 60lbs or so and the motor stays in the well all the time. Less than that allows easier removal, either to keep it out of the water to keep the growth off or to improve sailing performance.
Overall it is my opinion that you won't be able to do all that with a 9.9hp 4-stroke, so if you don't have heavy tides and currents in your local area, or anticipate motoring into heavy winds and seas regularly, you will do as well with a smaller, lighter motor.
Having stated definitive opinions will likely bring out dissent -- fire away, what else is the winter for, if not discontented griping?
Roy Jacobowitz
- Sea Owl
CD25 Hull#438
Monmouth Beach, NJ
I have a 9.9 hp Mercury Mariner that fits in my CD25, however it is an older 2 stroke with the handle removed - I have a 'remote' throttle/shift control (1 lever) that I use with the rudder to control under power - no help from the engine in maneuvering, just thrust. Also, engine does not do well with cover closed as it has an above water line exhaust and tends to smother itself. From what I have read on this board, I suspect an 8 hp two stroke would still give me hull speed capability if I had to go with a new engine (this one came with the boat). As pointed out by others, real question is, what do you need the stinkpot for? If for docking/mooring only, in a lake environment, i.e. minimal tide effects, I would think a smaller engine would offer what you need with a lot of advantages.
I have to fight relatively stiff tides here, and need to be able to hit hull speed to often go against the tide coming and going to my favorite sailing areas.
Good luck - measure twice!
Sea Owl
CDSOA Member #1144
CDSOA Member #1144
Electric outboard
I have been researching looking for a
Electric outboard for my CD25.
Ray Marine seems like the Best, but Big Bucks!!
Has any one every made the conversation?or investment?
Pros Cons etc?
Tom M
Pros Cons etc?
Tom M
West Wind
Tern About
Lake Superior
Yamaha looks interesting
I'm going to take a closer look at the Yamaha lineup for 2008. I think a 8hp 4-stoke Yamaha with power thrust may be the unit I put in the CD-25. A friend has one on his sailboat and loves it, especially in reverse gear.
- drysuit2
I’m in the same dilemma. I need to replace my old 2 stroke Mercury 9.9. The new 4 stroke models are just too big and to heavy for the motor well in my CD26. The problem is I really want an electric start,[bad shoulder] and really need an alternator charger.
Both Yamaha & Merc don’t offer an electric start in the smaller models. I really don’t need all that power a 9.9 delivers. But I want an electric start.
It looks like I can get a Nissan, or Tohatsu 8HP 4 STK with an electric start at about 81 lbs, but no one carries them locally.
Tern About
Lake Superior
Yamaha Catalog
Frank,
In the 2007 Yamaha catalog they do offer electric start and alternators for the 9.9 & 8hp motors. They reduced the physical size of the 9.9 by what looks like 1/4 -- there is an image in the catalog.
They offer a 4-stroke T8 High Thrust electric with a 6A alternator in 20 or 25 inch shaft. It weighs 102 pounds. It is available with or without a tiller handle. It also has freshwater flush. This is the unit I am interested in to replace my 2001 Mercury 9.9 (its going on my new inflatable).
See if you can get yourself a Yamaha catalog called "Reliable & Innovative Outboards -- includes rigging & accessories (effective July 1, 2007)". I got it from my local Yamaha dealer.
till later, Joe
till later, Joe
Yamaha 8 HP Engines
You can see an on-line Yamaha data sheet at
http://www.boatpart.net/cgi-local/listi ... ist&HP=8.0
The prefix F denotes the manual start class
The prefix T stands for the electric start class.
The number 8 stands for the horse power.
The letter S denotes a short shaft-15"
The letter L denotes a long shaft-20"
The letters EX denote an extra long shaft-25"
The letter M also denotes manual start.
The letter E also denotes electric start.
The letter P denotes power tilt.
All of the 8HP engines have a 6 Amp alternator.
The 8MSH engine is a two stroke engine and only weighs 60 pounds.
All the others are four stroke.
I hope this helps some.
Good luck in your search.
Tern About
Lake Superior
