Builder's Plate Placement on a CD22
trapper
CD25D, Lake Murray SC
Post by trapper »
I just received my bronze builder's plate from Bristol Bronze but I don't know where to put it on a CD22. Roger at Bristol suggested in the cockpit behind the tiller. Is that where the original was? Did they really mount that plastic one? :?: My plastic one was in the drawer in the galley.
I saw an earlier post where the plate goes above the companionway on a CD30 but that is not possible on the CD22. Help would be appreciated. Thanks. Fran.
Joe Clark
Post by Joe Clark »
Hello Fran, on our 1982 CD22d, the builders plate is located on the right side of the upper frame of the companionway.
Joe
trapper
Builder's plate location
Post by trapper »
Thanks Joe. That is where Ben said it should go. Do you know if that is the original location?
Gary M
1982 CD22
Marina del Rey, CA
Reply
Post by Gary M »
Hi Fran,
My CD22 has two builder's plates.
One is centered over the companionway and one is center on the teak board behind the tiller and below the main sheet traveler.
I believe these are original but who knows?
I bought a third one to cover a hole in the companionway bulkhead where a WM knotmeter used to be. It looks like this one is becoming permanent too!
Gary
Joe Clark
Post by Joe Clark »
Fran
It appears to be original. I see no evidence otherwise. Though we did not own the boat new, my quess is that it's the original location on our boat.
Joe
bill2
resurrected pic's
Post by bill2 »
FWIW - I dug put the pic's from back when I sold my cd22. I have a pic showing one plate on the starboard side of the companionway facing aft - as I recall she was an '82.
If you want to send me an email I'll return a copy of the pic ( jpg format )
Zeida
Post by Zeida »
On my 1980 CD25 which I bought brand new then, the bronze plate was located in the cockpit right behind the tiller, on the center of the teak board which held the mainsheet traveller.
Zeida
