Restoring 18.5 typhoon wekender
hi i have purchased y first boat "18.5 typhoon weekender" and i am looking for new sails, also i am just basically here for help, advice as this is my first boat and restoration. i plan oon stripping the bottom paint to the gel coat and then putting 3 coats of primer on should i sand the primer with 2000 sand paper before final bottom paint or does this not matter? basicallly if you have any advice i am open to any ideas thanks. andrew
Re: Restoring 18.5 typhoon wekender
[quote="alsaleen"] i plan oon stripping the bottom paint to the gel coat and then putting 3 coats of primer on should i sand the primer with 2000 sand paper before final bottom paint or does this not matter?
Alsaleen,
If you use 2,000 sandpaper, it would be polished so that you could see your face reflected in the finished prime coat.
(Just kidding)
Did you mean 200 grit sandpaper? I like to rough the surface up a bit with light sanding with 80 or 100 grit paper. It is my belief that the under coat, when roughed up a bit, provides better "tooth" for the top or finish coat to better adhere to it.
Git sailin'
Alsaleen,
Git sailin'
i did mean 200 grit. i am also wondering if anyone knows someone who has some used sails laying around, i bought my ty for $200 it needs new bottom paint a good cleaning and buffing , and the most important - sails. was this a good purchase? also i am missing a portlight, any ideas on how to rig something to look decent i am leaving for college next year and this is a low cost restoration "if there is such a thing".
$200.00 Ty?????????????????????
Alsaleen,
I'll show you what kind of an apple I am. I'll offer you $250.00 cash for your Ty, sight unseen. What a chance of a lifetime to make a fast $50.00 in a heartbeat. What's that? You say that you are holding out for $275.00? Okay, you've got me over a barrel. $275.00 it is.
And then I woke up.
Pinch me. Am I reading you correctly? You bought a Ty W/E for 200 bucks? You, sir, did excellent. I don't care what shape the boat is in, you did super. As time goes by, you will realize how well you did with the purchase. The sails? Fawgeddaboutit.
BTW, if you sell it, I get first dibs on it. If you really twist my arm, I might go as high as $300.00.
Between you, me and the lamppost, I've been selling fixed up Tys starting at $2,500.00 and upwards to almost double that figure. You hit the mother lode.
Okay, $325.00
Congratulations on your pocket yacht,
And then I woke up.
Okay, $325.00
Re: $200.00 Ty?????????????????????
AlsaleenOswego John wrote:Alsaleen,
Okay, $325.00![]()
No disrespect meant to OJ - but I'll go $326 !
Great boat - at an unreal price !
Good luck
OJ - no offense meant
NOT SO FAST
bill2,
I've got $350.00 burning a hole in my jeans pocket, and I'm prepared to go *ALL THE WAY.*
- s.v. LaVida
- Location: LaVida is a Cape Dory 33, Hull#40 Homeport of Olcott,NY
I can't miss out
MMMMMMMMMMMmm,
Perhaps I need a mate for my TY
I'll go 326.89.
Rit
I'll go 326.89.
Rit
$349
Alsaleen,
Apparently OJ is wanting to start his own northern CD fleet. Well he's got me -
but
I'll go $349 + $2 ( I don't think his jeans can hold more than $350 )
We'll keep this to ourselves so you can turn a quick profit and you can PM me with delivery options . . .
Good Luck
OJ - If you're set on this one, we could end this by partnering - six months each. Jan-June and July-Dec - probably save us from starting a bidding war with the whole CD Board
but
Good Luck
- Location: Cape Dory Typhoon Weekender(a friend suggested naming the boat DNR) no name, Westerly Rhode Island
As these guys babble back and forth about foolishly about the great price you paid I will ask the MOST important question...........THEN get to helping you...
ALSALEEN, hmmm, Does the name have anything to do with Saleen cars? Now THAT is more interesting than the bidding war when you have asked for advice.
I suggest you add that you travelled FAR and WIDE looking at every boat ever listed for sale, passing on great boats in order to keep the "quest" going................That might get you a real response, nothing worse than coming to check if you got the response you were looking for only to find it turned into a joke, where a never ending quest is taken on head first with great interest.
If you sand with 220 or greater than 150, it may allow the bottom paint to flake off. Also check to be certain the paint is compatable with the prime you use. Carefully read the manufacturers info on the can. Call them if you have questions, tech guys are great sources of info. Go to thier websites as well.
Peter Ross:
Etchell's 22
Evelyn 25
Bertram 25
'66 Mustang Convertible
(Ohlson 38)
Peter Ross:
Etchell's 22
Evelyn 25
Bertram 25
(Ohlson 38)
yes it refers to saleen mustangs. thanks for the offers but id like to enjoy working on and eventually sailing this ty. so it sounds like 80 gritt also i have an old 9 horse outboard laying around and i was just going to use that as my engine, i will be sailing the boat on lake michigan so some sort of motor will be needes just in case, would this 9hp be too large, its free and thats why id ike to use it.
Andrew,alsaleen wrote: i have an old 9 horse outboard laying around and i was just going to use that as my engine, i will be sailing the boat on lake michigan so some sort of motor will be needes just in case, would this 9hp be too large, its free and thats why id ike to use it.
"Would this 9 HP engine be TOO large?"
Ask 5 people on this board that question and you could very well get 7 different answers. So, here's my take on the subject.
A 9 HP outboard engine on a Ty is large, but not TOO large. But if the price is right, a 9 HP engine is just perfect for YOU.
You don't need 9 horses to push the Ty. From what I understand, many owners have an engine half that size, even one third the size of a 9 HP.
It's the extra weight of a large engine hanging on your transom that many owners will find fault with. A nine HP engine will not push your boat twice as fast as a 4 1/2 HP motor or three times faster than a three HP motor. When buying a new motor, a three or four HP motor will cost much less than a nine HP motor and weigh in at much less weight. They most likely use less fuel/mile, too.
I advise you not to open the 9 HP motor to full throttle . Maybe at a future time, you can do some horse trading for a smaller motor. Just a thought.
My 2¢
- RIKanaka
Smaller engines
Or in my case, with a 2 hp Honda, less than one quarter the size of the niner. I'm thinking of trying out an older 1.75hp Tanaka this year, just for kicks.Oswego John wrote:From what I understand, many owners have an engine half that size, even one third the size of a 9 HP.
Aloha,
Bob Chinn
Bob Chinn
ty weekender
I will trade you a set of original Typhoon sails for the weekender! I too bought a wreck of a 1976 weekender and turned it into a showpiece that gets accolades wherever I sail her. I have an older 4hp Mariner outboard and it is more than enough. When ou put too much weight on the stern she sits low in the stern and water might come into the cockpit from the scuppers. If you are interested in a main and possibly a working jib I have them. Would rather part with the main than the jib because I still use the jib when the wind pipes up after removing the roller furling 110 jib. $150 plus shippping for the main
"Cloning Around"
Lake Sonoma, CA
9 hp outboard on a Ty
No, no, no, no, no. More than 40 lbs will set you down in the stern. When you get to 9 hp you are probably 55 or 60 lbs. This will ensure that any water coming in the cockpit from the low side drain will fill in around your feet and you and all crew will hate it. You will be happier with one too small than one too large.
Serge
Serge
