I know some of you use Garmin 45 or 45XL GPS's. The BNC antenna is vulnerable to knocks and is broken easily as I discovered on the way back to CT from the Chessie last summer in my 25D. I also recall a cheap and simple emergency antenna that could be made up on the spot. Does anyone recall this? I think it might have been antenna coax but would appreciate leads.
jim
james.jamieson@yale.edu
Garmin 45 Emergency Antenna
