While sailing Saturday both the Loran on Ambuscade and a hand held GPS one of the crew had, regestered 6.8 knots. This happened a few times over a 6 hour time fame.
I believe the hull speed for a 28 foot CD was 6.3knots. Is this possible, or was it equipment error?
Tom
tgrant9008@aol.com
hull speed
Re: hull speed
The GPS records speed over land. If you were in a following current, you could exceed hull speed over land while still being below it relative to the water.
Joel
former owner Pokey II
'73 Ty #549 (I still can't let go!)
current owner Pokey III
'78 Pearson 323 #101
Bayside, NY
Joel
Bayside, NY
Re: hull speed
Hi Tom,
Hull speed is not a limitation but simply a benchmark used by yacht designers to define wavemaking resistance -- a point on a curve. Boats routinely exceed their hull speeds.
Hope this helps,
Andy Denmark
CD-27 "Rhiannon"
Oriental, NC
trekker@coastalnet.com
Hope this helps,
Andy Denmark
CD-27 "Rhiannon"
Oriental, NC
Re: hull speed
Thank you for the infomation. I notice your hailling port, any recomandation on a good resturant? I plan in being there next month.
Tom G
Ambuscade
Norfolk Va.
tgrant9008@aol.com
Tom G
Ambuscade
Norfolk Va.
Andy Denmark wrote: Hull speed is not a limitation but simply a benchmark used by yacht designers to define wavemaking resistance -- a point on a curve. Boats routinely exceed their hull speeds.
Hope this helps,
Andy Denmark
CD-27 "Rhiannon"
Oriental, NC
tgrant9008@aol.com
Re: hull speed
Tom:
Andy is correct. Also remember that as the boat heels over, the waterline increases. There is also a hull coeffencient(sp?) that needs to be used in the formula.
Glen
glen@hobbymarine.com
Glen
Re: hull speed
Tom,
A bunch of us will be attending the CDSOA General Meeting in Oriental, NC in November, Andy included. Don't worry, there are some fine restaurants in Oriental.
See you in November.
Cathy
CD32 Realization, #3
Rahway, NJ
Raritan Bay
C: Thank you for the infomation. I notice your hailling port, any recomandation on a good resturant? I plan in being there next month.
catherine_monaghanNOSPAM@merck.com
Cathy
Rahway, NJ
Raritan Bay
TomG wrote:
Tom G
Ambuscade
Norfolk Va.
Hope this helps,
Andy Denmark
CD-27 "Rhiannon"
Oriental, NC
