Volvo Penta MD7A Motor
I had to replace the injector tubes and need to know the headbolt torques and the valve settings, if anyone has a manual I would appreciate the information- owner of a 78 CD28.
Re: Volvo Penta MD7A Motor
According to the manual that came with my boat the data is:
Head bolts: 51 lb/ft
The manual suggests tightening in 3 stages. Stage 1 - 7 lb/ft; Stage 2 - 29 lb/ft; Stage 3 - 50 lb/ft (note 1 lb/ft descrepancy).
There is a specific tightening sequence that is easier to diagram than it is to describe, but I'll try. Orientation is standing in front of motor facing aft.
1. center right
2. center left
3. right edge rear
4. right edge forward
5. left edge center
6. center rear
7. center front
8. left rear corner
9. left front corner
Valves: 0.012" HOT for both intake and exhaust.
smwheatley@capecod.net
1. center right
2. center left
3. right edge rear
5. left edge center
6. center rear
7. center front
8. left rear corner
Correction to tightening sequence
Whoops, I gave you the sequence for the MD 6A which is covered in the same manual. For the MD 7A sequence is:
Again, orientation is from front of motor facing aft. The rest of the data is the same for both.Stan W. wrote: 1. center
2. left edge center
3. right edge rear
5. center rear
6. center front
7. left rear corner
8. left front corner
