Pressure Water System Fittings
Craig Curtis
Post by Craig Curtis »
The grey plastic elbow fitting (1/2 inch threaded male on one side, female the other)that connects a fresh water line to the underside of the sink has cracked and therefore leaks water when the pump is activated. Does anybody know who makes these or where I could get a replacement? West Marine, Boater's Discount World, Home Depot, Menards and regular plumbers have never seen such a fitting before. I'm hoping that there wasn't some marine plumbing manufacturer no longer in business that designed components that only connected with their own products.
Thanks in advance,
Craig Curtis
1990 CD40 "Coalescence"
craig_curtis@prusec.com
Duncan Maio
Re: Pressure Water System Fittings
Post by Duncan Maio »
Craig Curtis wrote: The grey plastic elbow fitting (1/2 inch threaded male on one side, female the other)
Craig:
If the threads are standard pipe threads, the part you describe is a "street elbow" and should be available at Home Depot or a plumbing supply house. I wouldn't get hung up on the grey plastic part; a PVC (white plastic) or bronze fitting would do fine.
mail@mysticmarine.net
