Bermuda trip
Bermuda trip
I am trying to work out the best course for a trip from South Florida to Bermuda, a rhumb line distance of about 874 nautical miles on a heading of about 60 degrees mag from West Palm Beach. I've had advice to ride the Gulf Stream north to Charleston and turn east, but that would seem to add many miles to the trip even if you add a knot or two to your speed. The rhumb line course seems more attractive unless there is something out there (the doldrums?) that I don't know about.
Does anyone have any experience, ideas,or advice based on reading?
Will
"Jambalaya"
CD30
whidlenp@flinet.com
Will
"Jambalaya"
CD30
whidlenp@flinet.com
Re: Bermuda trip
You could get as much as a 3 knot boost from the stream. For our speed-demon boats, that's a 60% increase in speed over the ground. All things being equal, using the Gulf Stream, you could go 1400 miles in the same time as your 874 mile trip without help from the stream. All things are never equal, though. Windspeed and direction as well as the actual current in the stream will have a huge impact. The best course to sail will depend on how all of these factors converge at the time of departure.
Having made the trip (in about 5 days in a CD 33), the rhumb line from Walker's Cay worked out very well without a single tack or diesel noise. We were lucky.
Talking to the winners of an Annapolis to Bermuda race, I found that they won the race because they went hundreds of miles off the rhumb line to catch the best winds. A good weather forcast can cut hours (days) off the trip.
Have fun. It's a great trip.
Bill
CD 28 "D.Ann"
shambora@ohio.edu
Bill
CD 28 "D.Ann"
shambora@ohio.edu
Re: Bermuda trip
I used to sail out of W.Palm Beach & found the stream moves between 3 & 5 knots. With the right winds the streem can be used for a good distance on a Bermuda trip. Not a fun place to be in a strong north wind, but who would try to sail N.E. in a N. wind.will parker wrote: I am trying to work out the best course for a trip from South Florida to Bermuda, a rhumb line distance of about 874 nautical miles on a heading of about 60 degrees mag from West Palm Beach. I've had advice to ride the Gulf Stream north to Charleston and turn east, but that would seem to add many miles to the trip even if you add a knot or two to your speed. The rhumb line course seems more attractive unless there is something out there (the doldrums?) that I don't know about.
Will
"Jambalaya"
CD30
john
cd31 #18 bonnie blue
redzeplin@yahoo.com
Re: Bermuda trip
Thanks, John, for your reply. You are right, the Stream is no place to be in a north wind. I have crossed it many times to the Abacos, once in a 15 kt NE wind. Never again with any component of North
Will
"Jambalaya"
whildenp@flinet.com
Will
"Jambalaya"
john doyle wrote: I used to sail out of W.Palm Beach & found the stream moves between 3 & 5 knots. With the right winds the streem can be used for a good distance on a Bermuda trip. Not a fun place to be in a strong north wind, but who would try to sail N.E. in a N. wind.
john
whildenp@flinet.com
Re: Bermuda trip
Thanks for your reply. I appreciate the sharing of your experience and it will clearly help me choose a route.
Will
"Jambalaya"
whildenp@flinet.com
Will
"Jambalaya"
Bill S. wrote: You could get as much as a 3 knot boost from the stream. For our speed-demon boats, that's a 60% increase in speed over the ground. All things being equal, using the Gulf Stream, you could go 1400 miles in the same time as your 874 mile trip without help from the stream. All things are never equal, though. Windspeed and direction as well as the actual current in the stream will have a huge impact. The best course to sail will depend on how all of these factors converge at the time of departure.
Bill
CD 28 "D.Ann"
whildenp@flinet.com
Re: Bermuda trip
I suggest that you take a look at the pilot charts for the dates of your trip. They will tell you the best route. As for me, I'd ride the stream as far as Jennifer says, and then hop off to grab an eddy.will parker wrote: Thanks, John, for your reply. You are right, the Stream is no place to be in a north wind. I have crossed it many times to the Abacos, once in a 15 kt NE wind. Never again with any component of North
Will
"Jambalaya"
john
saylr@adlelphia.net
