removing old ball valves
dan
Post by dan »
hey folks...is there any secret or technique to removing old ball valves from thru hulls? this one seems pretty well stuck on. its about 25 years old has a good deal of green oxidation on the threads as well as the rest of the valve body...
thanks!
dan
dan_iss@yahoo.com
BOB MORAVEK
Re: removing old ball valves
Post by BOB MORAVEK »
HI DAN, THE SIMPLIEST WAY I HAVE FOUND TO REMOVE OLD THRU-HULLS HAS
BEEN TO TAKE A 4 INCH GRINDER WITH A CUT-OFF DISC ON THE OUT-SIDE OF THE HULL AND GRIND-OFF THE INSIDE LIP OF THE FLANGE. IT IS SIMPLY DONE BY PLACING THE CUTTING WHEEL ON THE INSIDE LIP OF THE OPENING ON THE THRU-HULL AND GRINDING OFF THE BRONZE UNTIL THE OUTSIDE RING FALLS OFF THEN TAP THE REMAINING THRU HULL FITTING WITH A DRIFT/PIECE OF WOOD INTO THE BOAT. THIS TAKES ABOUT 5 MINUTES PER THRU-HULL.
DARKSTAR2010@HOTMAIL.COM
