rudder leak CD-25
Mike Spindler
rudder leak CD-25
Post by Mike Spindler »
When I turn the rudder while underway I am now getting water coming up along the shaft. This started coincidently after I had the boat pulled to clean/paint the bottom. But I'd like some idea what's going on and where this is suppose to be sealed before I just start taking things apart from the tiller down (teak floor plate, etc).
THANKS!
mike@spinsoft.net
Ken Cave
Re: rudder leak CD-25
Post by Ken Cave »
Check with the CD 25 manual, and see if the folks at Cape Dory addresses this problem.
On the CD 28, the manual tells us that this is a "problem", but can be helped by putting on some waterproof grease on the stem.
Hope this helps
Ken Cavde
bcave@whidbey.net
