I know it's been mentioned, but I continue to have problems with the site's search function. Our noskid on the cockpit sole is being repainted and they've got the color wrong. I saw mention of the color of the beige gel coat, but does anyone know the paint color for the Cape Dory Beige if one was just to repaint the noskid? I appologize if this has been discussed endlessly, but I want to let the yard know today before they mis-guess again.
Brian W.
CD33
Beige No Skid Paint Color
Re: Beige No Skid Paint Color
Hi Brian,Brian W. wrote: I know it's been mentioned, but I continue to have problems with the site's search function. Our noskid on the cockpit sole is being repainted and they've got the color wrong. I saw mention of the color of the beige gel coat, but does anyone know the paint color for the Cape Dory Beige if one was just to repaint the noskid? I appologize if this has been discussed endlessly, but I want to let the yard know today before they mis-guess again.
Brian W.
CD33
I can give you a match in gelcoat. Contact Gel Coat Products at the contact info below and give them the year of your CD and they will have a matching gelcoat.
For my '83 CD30 the nonskid beige is #053097. White is #042997
I've never tried it but Z-Spar Miracote Grand Banks Beige single part polyurethane seems fairly close in color. You could also get a sample of the old color and have an automotive paint body shop supplier like Sikkens, Dupont or Sherwin Williams do a color match to the original gelcoat. Just have them mix a two part polyurethane.
GEL COAT PRODUCTS
P.O. Box 17336
Seattle Wa. 98107
PH: 206/781-1162
FAX: 206/781-3177
Hello all,
Just one note of caution concerning adding non skid sand to the paint to give it texture. It will change the color! (darker!)
From experience I can say 1. you don't need as much sand as you might think. 2. Never pour it directly into the can of paint (make your mix in a separate container like a paper bucket). and 3. spend the money on good "fine line tape".
This what I did on my previous CD and my Dyer dink I think on my new CD I am just going to paint over the texture that is there.
Chris Cram
CD 30 C
goin in the water 4/27 --- the yard promises!?!?!
cccobx@prodigy.net
Chris Cram
CD 30 C
cccobx@prodigy.net
