This past weekend, I looked at a Cape Dory Typhoon Weekender, in reasonably sad shape. I have two questions:
1. The cradle is not the proper size for the boat. One of the supports pushes into the hull, creating a dent, about 1/4 - 1/2 inch deep, and about 10 inches in diameter. I found no crazing corresponding to this post on the inside. This dent doesn't look good, and often "if is doesn't look good, it isn't good!" But, specifically, what damage does this cause, and what can be done to fix it, if anything?
2. The teak is terrible: the grain is raised quite a bit, parts are (gently) warped and no longer secure to the fiberglass. There is not much teak on this little boat; what is the cost of replacing teak?
Otherwise, the boat appears structurally sound, in my unexperienced opinion. Some crazing here and there, and my "professional"
I am new to keelboats; my keelboat experience consists of crewing PHRF races (i.e. very little maintenance). Otherwise my sailing expereince comes exclusively from boats that I can carry to the water, drop in, and sail away. But the Typhoon seems a pretty sturdy boat, has berths similar to a pup-tent for limited overnighting, and is simple enough to make the transition.
I know to get a survey for any boat before I buy, but what are the opinions of these matters on the group?
(BTW, the asking price is $2k, including outboard, no trailer.)
Thanks!
Michael Muller
GSRA
University of Michigan
Aerospace Engineering
mullerm@umich.edu
