Removing Vinyl Lettering
Lyle Lunson
Post by Lyle Lunson »
I was wondering if anyone had any good advice on removing vinyl lettering off without completely scratching the gelcoat up. A razor blade just seems to take sooooo long.
Lyle
Intrepid 28
(Can't think of a Name)
lyle@lunson.com
John Nuttall
Re: Removing Vinyl Lettering
Post by John Nuttall »
Maybe a Heat Gun on low.....or a hair dryer?
Then use adhesive remover or acetone to get off the glue....
I don't really know, but that's what I'd try... :-)
aimless@nc.rr.com
David Brownlee
Post by David Brownlee »
Hair dryer and putty knife followed by cleanup with paint thinner worked fine for me.
David Brownlee
CD31 #1 newly renamed WINDRUSH
Havre de Grace, MD
dbrownle@sas.upenn.edu
Bill
Post by Bill »
I just completed this task last week. I used a GOOD pressure washer to get most of the lettering and then acetone (sp) and you cant tell where the lettering was (after three years).
bill
Lyle Lunson wrote: I was wondering if anyone had any good advice on removing vinyl lettering off without completely scratching the gelcoat up. A razor blade just seems to take sooooo long.
Lyle
Intrepid 28
cd25d@rhapsodysails.com
Duncan Maio
Post by Duncan Maio »
The recommended removal technique is a little heat from a hair dryer or heat gun, and a little patience. Adhesive remover may or may not be necessary, depending on how warm the underlying surface is.
Duncan Maio
mail@mysticmarin.net
John R.
Post by John R. »
Go to your local auto body shop paint supplier and ask for a vinyl graphics or vinyl stripe remover. It is a 3-4" diamater by 1/2" thick soft rubber wheel with an arbor that you use with a drill and it just abrades the vinyl right off. They work beautifully. No they don't damage the underlying surface. Use it at the recommended rpm. When finished just do a quick wipe or two with a clean white rag and some naptha (lighterfluid is the same thing). Perfect job when finished.
Lyle
Intrepid 28
